Ports Audiowizard Used in Rear Deck??
Yedi
ya, the Monte over there.
Audiowizard, what size ports did you use in the rear deck of your car. I'm going to do somthing similar, but the ports won't be hooked directly up to the box. Whats the cheapest place to get them? Thanks Man.
The ports in my rear deck are 3" x 13" with a 90 degree elbow to clear 12 disc changer chamber. The ports I use are regular plumbing pvc with hand chamfered edges (too reduce port whistle). You can get that stuff at any hardware store relatively cheap, hope that helps you some.
