9
99redsnake
Guest
I've got a bank to bank system on my Mustang. 83 lb/hr injectors, wide band, the usual.
Anyway, the idle quality and drivability of the car was fine tonight when I started the car and drove it for about 15 minutes. Then, the A:F ration all of the sudden went to 15.94 and it refused to idle. I tried restarting the car several times but it would fire and and then die. I pulled all of the plugs and all were lean - extremely lean. I was also noticing that I can't adjust the idle with the IAC, it simply has no effect on the idle no matter where I set it in the idle vs. water temp table.
I'm very confused. I need advice from the gurus. Do I have a bad IAC, a bad O2, or am I just stupid? Why did this happen after the car got warmed up and ran fine for 15 or 20 minutes?
BTW, great site! I've looked around awhile and just now decided I needed the advice of the pros. Thanks in advance.
