Postons 202 cam kit
volvoman
The Green BEAST
I was just wondering if anyone is running this cam set up.. I will have a power plate and stock heads, rrfpr.
Also what other cam would you guys run with this set up? I want to upgrade the turbo and injectors down the road to run 12s.
thanks
Chris Lindsay
87 760 volvo wagon hybred
I run a Poston 107 cam. The only reason for me is because I wanted a cam that would pass emissions (my stock one needed replacing during a rebuild) and provide a little extra performance. If you search previous post about cams, most will say that you really don't need to change cams to get to 12s. The 107 cam idles smooth, and seat of the pants acceleration seems okay to me. Now my combo is coupled with Chevrolet 1st racing design camshaft valve spring (just a touch heavier than the Poston recommended spring), but Poston said it woud work fine. With regards to emissions, non-attainment areas of CA test for NOx and as the lobe center (LC) number gets bigger, so does cylinder pressure and that may increase NOx. The other cam that is close to stock LC is the ATR RP313B and the Lunati 200 camshaft. I thought the lift was a little high on the ATR cam, and the price was better for the Poston cam as opposed to the Lunati cam. I currently have approximately 15000 on my new engine and it runs great. The car recently passed the smog test pretty cleanly. So, my goals were met. Also, I'm in the 18mpg range.
The Poston's 107 cam with 202 duration is supposed to be a very close match to the original cam offered in these cars. I sent mine back though because I wanted a bit more cam, and saw where a lot have gone with Ramcharger's 208 cam. I think you'll be fine to go with the 202 and meet your goal of 12s.
If the stock cam is healthy no reason to change it. Save your money. Stock cam works just fine deep in the 11's/high 10's. The stocker can handle 12's no sweat.
The only reason I am thinking about this is because the motor is not in my wagon yet.. Thanks any more info would be great.
Chris Lindsay
