Power front seat removal help
jacksorroche
I'm removing the drivers seat of an 86 Limited. It is a power seat that is all the way forward with the motors not working. I can't seem to get to the front bolts. Is there any way to move the seat back manually?
First check to see if there is some 12v. going to the motor...If not, you'll have to disconnect the cables from the motor and with a small screwdriver, turn inside the little square opening (in which the cable was located) to move the seat forward or backward. Take your time as each turn moves the seat a small amount only .....
Claude
