power logger readings
luisturbog
UNDERDOG HOT AIR !!!!!!!
anybody with a power logger that has a maft and ls1 mass air sensor hooked up that can tell me if it should max out at 255 on power logger? At wot of course!
I have a standard MAFT with a LT1 MAF, and I hit 255 on my system. Specs below in my sig for my combo.
Are you trying to decide to go with a Gen2 and double your A/F in readings?
Remember that you will need to run an extreme chip to take advantage of that feature, as Eric does not support it with his chips. I thought I would mention it...
Mike
That depends on the chip you're running. If you're running an Extender chip, then I doubt you'll ever see any maf flow numbers any where near 255.
If however, your not running an extender, then yes, you will be able to easilly hit the 255 limit.
