To use a Wide band O2 sensor with the Power logger , Does the Wide band sensor connect directly to the power logger or is there a interface between the Wide Band O2 senor and the power logger?
The Powerlogger comes with an analog interface device that has inputs for several different analog devices, like:
WBO2
MAP sensor
EGT (with optional amplifier)
Scanmaster
a couple of other inputs that are user selectable
No amount of evidence will ever persuade an idiot.
Powerdex A/fxwas easy to install and worked perfect right from the start. They use a nice plug that is easily removeable so a small hole can be drilled to run the wire.
