G GSP Member Joined Nov 5, 2007 Oct 28, 2018 #1 I think the ball is bad on my Power Master. The pedal feels fine, but I can hear the Power Master running and the brake light on the dash will flicker. Is it as simple as just unscrew and replace?
E earlbrown runs with scissors Joined May 26, 2001 Oct 28, 2018 #2 You have to pump the brake pedal until it's hard as a rock with the key off. Otherwise the acccumlator ball might reach low Earth orbit when you get to the last thread.
C Cyrus72 Active Member Joined Oct 22, 2017 Oct 28, 2018 #4 earlbrown, when yo usay with the key oiff. Do you mean the key in the ignition in accessories mode? Sorr yOP don't want to hijack your post.
E earlbrown runs with scissors Joined May 26, 2001 Oct 29, 2018 #6 off, as in on your coffee table. It that accumulator gets any charge, you'll know it when it breaks the sound barrier.
