black87Ttype
- Jul 2, 2014
The power master went out on my car. Was thinking about the Hydro boost kit. The price is up there, but I only want to do this once. Feed back on the Hydro boost ?
SignUp Now!Would you want to do the work?Suggest a search.. Been many threads/posts on the topic.[Including mine w/ pics]
I like the price ! Did you change the pedal?Just installed a vacuum unit on my GN from advanced auto, for an '87 regal, works perfect... $160 for everything...couldn't be happier.... Mike
No I did not, I mocked everything up, drilled a hole and welded a proper size stud in place where it belongs with the new booster, I also left the original pm stud in place, so it still could be used ....MikeI like the price ! Did you change the pedal?
I used the larger one for a late 80's Caprice and it works better than the powermaster.I got it at Oreilly's for $122.00 or alot of others here have used the one for a Monte Carlo SS with good results.I like the price ! Did you change the pedal?
