BuickMike231
60% of the time, it works every time.
- Feb 21, 2007
Hey guys, I recently found a puddle of brake fluid under my car right behind the drivers side front tire in line with the frame. Best I can tell, it looks like the hose that runs from the PM motor up to the hard line that goes to the master cylinder is what's leaking. It appears to be dripping from that lower connection on the motor end of the hose, is this common? Also is this hose available anywhere? I didn't see it on Kirbans or G Body's websites.
Any ideas or do you guys think it could be anything else? The frame directly below that connection is wet and the fluid runs down the frame and drips behind the wheel.
Any help is appreciated! Thanks!
