power master motor
kraus
I am either looking for a good used power master motor or some info on if can rebuild myself. Or a place to by a rebuilt one. I have new ccumulator,master,proportion valve in brass already,also switch. Notor is bleeding back pressure,so wil not build pressure needed to shit off.So anyone got a good used one want part with?
When you say bleeding back,do you mean a large volume of fluid is entering the reservoir through the port (in the floor of the reservoir) closest to the firewall?
If i shut off air comes back in thru the port on front port of tank. Motor runs all time when driving.i shut off and air comes back thru front port towards raditor.
