motor is shorting out...i would not drive it, a lot here go vacuum set up, couple of vendors sell a kit for like $200. also motors available new....forget the guys name, he is out of twinsburg ohio....new motors are $160. i just went through the whole power master thing and ordered one from kirban......$415....not bad considering you get the acc. ball and new switch....it does not appear to have a new motor....and i do not think the motor was rebuilt.....cardone does the rebuild....some have had good luck, others not. the change out is not difficult, the hardest part is that small clip holding the brake pedal on. after that it is just 2 lines and two bolts. contact me if you need help. on the board, zeus was a real help.
