Originally posted by Ormand
I'll say this slow. The power plate prevents overboost in the rear cylinders. Again.. The power plate prevents overboost in the rear cylinders. That means the engine is not limited by cylinder 5 and cylinder 6. You can then increase boost, and all six cylinders will see it evenly. You will have more boost in cylinders 1, 2, 3, and 4, not less. Cylinders 5 and 6 will be about the same, since they were already "knock limited". If you turn up the boost, you will have MORE power. Note that you may already be fuel limited, so that when you turn up the boost, you MAY need more fuel, too. The Powerplate corrects a distribution problem that the small stock plenum causes, and allows all six cylinders to make max power. With the stock plenum, the rear cylinders get more air, and limit the power output of the engine by reaching the knock limit before the front cylinders.
