Power Source For Computer
PaulRV6
I have a new Dell computer that I am using for my TL. What is the best source for alternate power if my battery goes dead?
Is it an inverter or can I just get an adapter to run the computer?
paul
inverter
I bought a 150 watt ( more than enough) at Walmart recently for $30---Later saw one at Sams Club for $18. One of my Bestest friends gave me an older laptop so I had to have an inverter.
Inverters are a huge PITA!! Electroncally "noisy" and randomly unreliable.
I much prefer a direct DC/DC converter. They're made by Targus. A tiny little box that has a cable to plug right into the cig lighter, and a cable coming out of the other end to go directly into the laptop's DC power input. Comes with adapter to fit most laptops.
It's output is automatic (3-24vdc) that provides what the laptop demands.
Can't go wrong.
Mine is a PA160. expensive, maybe, but trust me, it will be reliable, small, rugged! The box it's self is smaller than a cell phone.
MORE INFO!!
TurboDave, where do you buy something like that and how much do they cost? Are there many different types of these DC/DC converters out there?
Thanks for the suggestion.
paul
I'm sorry, I should have included the link, I meant to.
http://www.targus.com/accessories_power.asp
The only other type I've seen is one I have for my Compaq. I got this Targus because I needed it for my work laptop (DELL), but it came with extra connectors that allow it to also work with my COMPAQ.
I love these things. They're small, unobtrusive, develope no heat, no RFI or EMI (the inverters are notorious for). All around, the best bet.
I'm confused (doesn't seem to take much) but both of the ones mentioned are not for use in an automobile. It looks like the 360U or 380U from what I can tell.
Is this correct?
paul
The one that Dave mentioned is for a car. It plugs into a cigarette lighter and avoids the use of an inverter. The one I just happened to mentioned is an AC adapter that plugs into a wall socket and works with any laptop. It can be used in a car if you have an inverter but no power cord for a laptop, but that was not its purpose.
Well I just looked at Targus website and PA160U is for use in a 120v wall socket????
paul
http://www.laptopsforless.com/
I got a dc to dc power adapter for an old Toshiba laptop I use for turbolink. It plugs right into the cigarette lighter and works fine, plus it has variable voltage settings and I can use it with my new laptop also. You should be able to find and AC adapter also, but a new laptop should have come with it already. Hope this helps.
DUH. You are correct, I meant say I wanted a 360, the type that plugs into a cigarette lighter. Based on Dave's description, I think he meant to say 360 also.
The one I have is a universal AC adapter with the 6 power tips that pretty much covers almost all laptops.
Is this the one you are referring to? Looks like an inviting price.
http://www.laptopsforless.com/laptopaccessories.htm
Yes I meant 360. I mind and fingures were disconnected the other day ;)
All of the DC/DC converters are essentially the same except for the adapters that and laptops they're designed to run.
Nice, yet another case where a search dug up an 'old' post that answered all my questions and then some. I was gonna ask what kind of rating I would need for an AC adapter to run my laptop, which of course would plug in through an AC-DC inverter. I was looking at dropping $50 for a 100w DC-AC to plug into the car.
Since the laptop is the only thing I'd run, DC-AC-DC seems to be LESS than optimal. Thanks again to TurboDave for another great idea.
BWallace, you have an old Toshiba as well? I run a Satellite Pro. 2150 I think. It's a 486-80...more than enough for DirectScan. I will delve into the site more later, thanks you guys!
