Power Steering Feel!!!
Mad_Trbo
I am working with a '87 T-Type and wondering if there is anything that can be done to tighten up the steering feel. I would like to tighten it up it currently feels like a big luxury car. Any conversions you can do with it?
on the gearbox thee is 2 adjustments one you can see in top ov the box and one you cant. it has a cover on it and is a apita to take off so try to tighten the top one a little at a time. little movement makes a big adjustment.
So to have total adjustment you need to have access to both, or you think the one that is visible?
What does the adjustment look like, is it an allen bolt or regular bolt. Additionally I am assuming the gear box is at the end of the steering rod, easy enough to find right?
should do both. the top is a allan screw. loosen the nut and turn the screw. on the left side at the end of the steering rod. should be easy.
GM made several steering boxes that will fit the Regal. The one which was used on some F bodies has the best "feel", and will swap in. Some company, can't remember the name,, specializes in setting up these steering boxes.
