Go here and solve your problem, they can supply you with a high pressure pump, or rebuild a factory unit, the endless posts about "part store" replacment pumps and boosters is proof enough to buy a new high quality unit, we are talking BRAKES here, no place to cheap out.
PSC Motorsports Online
Great guys, very helpful and quick shipment !
I am mid way thru my Hydroboost swap now and am using the Alum reservoir, will have some billet brackets avail soon to make it a bolt in to the factory location (will have 3 extras after this weekend) do the Braided teflon line kit also, get it from Welcome to Hydratech Braking Systems :: High Performance Hydraulic Brake Assist Systems
Same thing, only new high quality components, very, very helpful !
OK, off my stump and back to the 14 bolt rear rebuild on my GMC
Thanks for those links. I had been wndering if the pump could provide enough kick for the booster and steering. Do you have any pics of the hydratech system? I was thinking of doing that and doing all the lines with aeroquip so they last a long time.
I'm also planning on doing the Canton p-steer reservoir with Aeroquip lines as my return lines are dry and crispy, not to mention they leak. (What do you expect after 25 years of engine compartment heat right?
