Who makes a good power steering pump for our cars? I converted to hydroboost and now my pump is noisy (I think it's just old and wore out and the extra load finished it off). My Steering box started leaking too, anyone make a good one? Thanks!
The noise is most likely from the fluid getting aerated. It's a common problem if things are not plumbed exactly right. There's also a restrictor available to slow the flow rate down which helps. A friend of mine just went through this. That's why I converted to vacuum. A lot cheaper and more simple and works great.
