I suspected the connector because when I replaced the switch, the exact same problem stayed. Anyway, I installed the "good used" connector (actually it was in near perfect shape; I was surprised) and it seems to be working perfectly now. Just before replacement I had to jiggle and push to get the drivers window to go up. Here's hoping that was it. The replacement connector had the same color wires in the same place except for one so you have to take pictures (or notes) before you start cutting. Just a tip.Mine wasn't the switch. The wires in the connector were FUBAR. Once I fixed that the switch worked fine for years and was working fine when I replaced it for cosmetic reasons. My aftermarket switch is working fine although that's only been in 8 months.
