I tried sending power to the blue and black wire were the switch mounts. I will try the motor connectors. I'm guessing the motor is shot. If so is there any way to do it manually?
If the glass don't need to be in the car it took me about 5 min to pull the glass out just need to unbolt the stopper the 2 guides and 2 bolts holding the glass in
No way to do it manually. Try power right at the motor and see if that works. If not you could try to unbolt the two 10mm nuts that hold the glass to the regulator like stated above.
I'm not sure but I think the window has to be down a bit to get the glass out? If your replacing the motor just take it out. Once you take the motor out the window track will come down. Make sure somebody is holding the glass.
