Originally posted by WE4
There is no BOP PG.
Bruce
WE4
WRONG ANSWER!!!!
Yes, there IS a BOP Glide case. I've sold several. Whether or not I can get any now is another question, but I can ask. The turbo 350 plant burned around 69 or 70, and GM used PowerGlides instead of 350s in the BOP cars.
I ran one in a 70 Grand Prix at the local circle track because they had a no Chevrolet rule. Pissed them off when I ran it and they said it was illegal because it was not available. Pissed them off even more when I proved it was and made them give the money, the wins, and the points back.
I can get planetary sets from the 1.6 zone up to a 2.18, in helical or straight cut. Use a turbo spline input shaft, and a STEEL direct hub. The best brake is the EXTERNAL solenoid.
If you have a good tube frame, and good engine plates, you can mount the tailhousing to a solid crossmember, but I prefer to use a stock mount with two radiator hose clamps.
With the weight and power you currently have, I'd run the 6 cylinder 1.82 low gear set. The aftermarket gear sets are based on that cage anyway, so you can use the same turbo spline input shaft with any of them.
If you have nothing at all to start with, figure on about $2K for a Glide with converter and accessories. This includes a case (ATI may be the ONLY place that still has a BOP case), a core (you'll need it for the pump, bolts, tailhousing, and internals, an input shaft, a direct hub, a valvebody with a brake, a converter, and the two shields. If you are lucky, you'll find a core that has a 1.82 planetary in it.
