If you have a dual post battery then its really easy to do. Just run a power wire off of the second terminal and then run it to the back. If you have only 1 modest amp and can get by with 8ga wire then just run it through a grommet in the firewall and under the carpet/backseat to the trunk. If you have a little more power and go with bigger wire you could do like I have done, take it from the batt then run it along the fender well right into the frame. I then have it tie-wrapped in there and it enters the cab under the back seat through a hole I drilled. It then goes into the trunk from under the seat.
