Short answer - No.
It will vary depending on the condition of your seals, your accumulator and your pump. If your Powermaster is in excellent working order, maybe 2 to 3 or even 4 pedal presses before it would/should need to come on again. The important question is how long does it run when it comes on. If it only comes on for a moment or two, the motor is pumping up well. If it does it frequently (like you have already mentioned) the pressure is not being held within the high pressure side of the unit. The Accumulator ball or cylinder itself could be at fault.
