Derale external transmission oil cooler
I use the Derale 51606 with Aeroquip line & fittings. I go from trans to radiator, out of radiator to external cooler, out of external cooler back to trans.
Where’s yours mounted at? Front of the radiator?
I have mine mounted to the core support just below my ESP front mount.
Sits inside my box in set-up from GNS. So it still gets the airflow from the grill.
Here’s what I’m running in my car, it’s a LPD (Low Pressure Drop) De Rale
"Seem to have been cut to connect to rubber lines that flex up and connect to the cooler which is attached onto the front of the radiator. "
Sounds like you already have a cooler mtd.
Being the trans is fresh, just replace the current part with a newer more efficient piece??
Ive got the 13960 on mine with the jiffy qd and -6 an lines to trans.
That’s my plan, just looking for a better one or better ways to mount. Mine is by Hayden. However I’m seeing ones with plates saying that the plates are better than tubes and fins. Looking for an upgrade probably
