billygeg
- Oct 5, 2009
Hey Guys
My brakes give me trouble usually for the first few minutes when I take it out every few months..I usually get a hard brake pedal then it goes to normal with no issues..I took the car out the other day and the pedal never got soft...I have heard threw many threads all about the accumulator..When I bought the car the guy gave me one new in box so I replaced it..Same thing, Hard pedal..Now I am hearing about the pressure switch..I read up alittle bit on how to test it and it says there should be continuity between all terminals on the three pressure switch terminals..Not so..there are three terminlas on the unit..Lets call them A, B, and C..I get no continuity from A to B but I get a half second of continuity from B to C..I was also told that I could jump it out..So I turned the car on and jumped out the connector for the pressure switch..Like a dumb ass I forgot to put the pressure switch back in..Anyway, I do know that the pump is working because I got a small geyser shooting up from the hole the pressure switch is mounted to! DUH!..So I think (you guys tell me) that the electrical and the motor seem to work..Can I assume that the pressure switch is bad because I do not have continuity between the terminals on the pressure switch as stated in the directions on how to test it? Im just checking to make sure I understood the directions on checking it properly... If the switch is the problem does anyone knopw where I can buy one..I went to advance auto and they cant even get it..
