powermaster
gnxis
these brakes suck. I cant seem to get a very good pedal. Ive done every thing i know of and they still feel like sh..
also power master seems to be very loose on bushings where it connects to mc. is this normal? i dont see how but could this cause my problem?
Not many responses to your question. Probably because many are at BG and I'll be there tonight!
Mounting will have nothing to do with your problem. The PM is a great system if all is in good working order and the brakes are adjusted properly. You should upgrade your porportioning valve to the brass replacement available through GM for about $45. Make sure there is no air in the system and the rear shoes are adjusted correctly.
Check out the diagnostics area at GNTTYPE.ORG for more info.
Good luck,
Hank
