GNONYX
- Oct 16, 2009
Hi All,
I want to thank Buick members: aminga, DJ Red Barron, Fast4Ward, Mike70gtx, ThaBozz89, and others for their input and advice of the Rear End Seal Installation. I took my time making sure everything was done correctly since I didn't want to do it again. Since then I have replaced the oil pump screen, valve cover gaskets, Radiator hoses, all of the heater hoses, spark plugs, spark plug wires, upgraded the stock injectors to 60# injectors, and fuel regulator. I didn't add the hot wire system since I haven't had the chance to place an external fuel gauge to see fuel pressure reading at WOT. I did ran the car to about 70mph operating with the replacement fuel pump I replaced years ago, and car ran good and without being staving for gas, but I still don't know if I'm getting the right amount of fuel pressure at WOT.
I also installed a Pre-Lube Oil System since I don't drive the car every day. I did check out other Pre-Lube Oil Systems, but in my opinion I like this since less electrical parts is needed. If anyone is interested in this system check out this web site: AutoEngineLube Pre Lube System Reduces Engine Wear Up To 60%
Also checkout my installation pictures. I will be adding a timer in order to capture the high end oil pressure in the Accumulator tank. I'm using 20-50 oil grade; car idling temp 173* with oil pressure reading of 35psi
If any would like to order this system please use my name (Julio) as referral.
