Depends on the harness I guess. My original FAST setup, purchased through Precision , ran without the pink wire in the harness connected (called Fel-Pro back then serial number 342). it just gives you full battery voltage. Turn the key on and make sure you have voltage at the injector harness and you will kow for sure. Are you not wanting to hook it up, or just trying to test it out quickly?
