Precision Turbo 67 gtq ball bearing turbo.
rock105
May have 500 miles on the turbo have since went with a 76 mil turbo and do not need this anymore 900.00 or best offer will not be displeased with this one.
What compressor cover? 3" in 2" out or 4" in 2 1/2" out? Anything included - water lines, actuator etc?
It could be in raised numbers on the exhaust housing - maybe somewhere near the exhaust entry?
Also - are you letting the actuator go with it? If so, is it a high pressure (18psi) or low (13psi)?
Double check that inlet and outlet size - I think they're only available 3" in 2" out (E compressor) OR 4" in 2 1/2" out (S compressor)
Not trying to give you a hard time - just need to know what we have here. Pics would be great. craig@michaelthomas.com Thanks Craig
It is setup for a external wastegate. I used the old applied tech one. I am thinking it is a .63 but I will check to be sure. It is in great shape but don't have a way to get pics on my computer. I bought it new from Cal Hartline.
