No it shouldn't, check for a restriction at the charcoal canister filter or the vacuum line to the evaporator switch on top...You haven't plugged off that line, have you?
Sure will, Ive noticed it turns over a lot before it starts when its cool, And when it finally starts it floods just a little bit, could the pressure in the tank be causing this?
