Pressure In Fuel Tank
moose
My fuel tank has a lot of pressure in it when I go to the gas station, Should it have pressure? Or not?:confused:
No it shouldn't, check for a restriction at the charcoal canister filter or the vacuum line to the evaporator switch on top...You haven't plugged off that line, have you?
HTH - Jimmy
Sure will, Ive noticed it turns over a lot before it starts when its cool, And when it finally starts it floods just a little bit, could the pressure in the tank be causing this?
