Pressure problem?
Black rider
Hello all, new to the forum :D
Have a question about my 200, pressure related.
When I hook my pressure gage up, I get weird readings.
My original problem was a soft 2-3 shift under full throttle, I decided to hook the pressure guage up and do some checking on line pressure to see if it was within spec. At idle I would get 175 park, 290 reverse, 175 neutral, 220 OD, 220 drive, 275 2nd and 275 first.
Now, I went out and drove the car and found I am only getting 170 all the time in drive gears under full throttle :confused: Not even a flare or dip when the gears would shift either.
What could be causing this pressure drop? the trans only has 2000 miles on it, and the TV cable is spot on.
Any insight would be much appriciated.
