Ok..a little discussion.. the subject is alky pressure and boost levels. On another post Steve from SMC made a valid point that if the boost level increases so has to the alcohol pressure level to keep things in line. Same thing as our fuel pressure regulator having to increase pressure with boost to keep the A/F happy.
So .. if your at 12 PSI and spraying 60 psi from your alcohol pump, thats a net 48 PSI. Once your boost goes to 25 PSI thats a net 35. Seems backwards to spray less alcohol as the boost increases..
Does it matter that the net pressure amount is less when the boost increases? I have seen the pattern out of nozzles with the pump spraying at atmosphere..pretty intense at 60 PSI..but never seen what effects occurs when the spray is directed into a pressurized space.
So if I set my pump to 25 PSI and run 25 PSI boost..that would be zero alky.. Am I off or what?
Julio
Julio
		 .  More pressure and flow could be better if I need it in my typical application.  I'm still at the original 60 psi of my Shurflo pump, same diy alky kit I started with, and I'm at mid 12s on street tires.  One might guess I would have lower times on slicks.  So I guess what I'm saying, mainly to  those who wish to install alky for the first time, this rocket science is fine, but don't worry about it.  This thread will not help you.  You'll be able to go 11s even if you're just a dope like me.
