Did a little bit of racing against a few friends (modded EVO and whippled Lightning) and was taking the GN back to the shop and was doing a couple 1-2 gear burnouts. Ever since I had the car the 1-2 shift was very solid and hard, however the 2-3 shift was soft and would slip under part throttle. At WOT it would shift 2-3 pretty firm. 3-4 shift was always firm as well.
Well I get back in the GN today and take off down the road and the "shift" to 2nd gear was basically nonexistent. Once it was in 2nd it basically free revved. If i dropped it in 2nd gear manually it would hold a little better and make it through the gear but still wouldn't hold that much power. 3rd gear will hold all the power though and layed a few tracks down at about 40mph. I never got it into OD though and took it back to the shop. I checked the tranny fluid and although it was in the middle of the "add" section, the fluid looked clean.
So tell me trans experts, any hope left or am I in for a rebuild or new tranny? Car was making 352rwhp and 441rwtq at a little lower boost and lower timing (TE44 on meth @24psi, built motor, ported heads, stock IC, etc). I was told it was an Art Carr tranny and Art Carr 3000 n/l stall when I bought it. Never really checked underneath the car as everything else listed when I bought it was correct. I'm planning on going bigger so I guess it wouldn't hurt to upgrade.
At least I beat the Lightning and EVO :redface:
