josh young
- May 12, 2008
I figured I'd start another thread on this issue I've been having. The gauge is a Prime brand, can't find anything about them doing a search. I've been over all the connections under the hood and on the gauge I can find, hit everything with contact cleaner, checked for loose nuts. etc. It has a wire that is made in the gauge, I assume it's the wire to the sender. It also has one for ground and one for power. There is also a purple wire on the top of the gauge that is not hooked up and does not appear to have ever been, I don't know if that's another option or? The best way I can describe it is as follows: When you turn the key to the run position it's right there with my manual gauge give or take 1 psi. The readings start low then go up in the run position. When I start the car the digital gauge readings start to automatically go down to around 10 psi then slowly come back up. It will go back up to the mid 20's, but never as high as it was before I started it. I thought about buying a new gauge but I don't know if it's my issue. I've searched the internet high and low and this seems to be a scarce issue, or at least one that's not talked about. Thanks guys for the information in my other thread, I checked everything I could to no avail. I thought it might be better to start another thread with as much information as I can give in it. If I find the issue I'll update both threads, in case anyone happens to have this issue in the future.
