If you've already assembled it without the vaseline, you can get a "funnel" from Checker/Schucks that is a clear tube with a valve on one side that fits a quart of oil. You disconnect the oil cooler hose (Believe it's the lower on the radiator) and slip that clear hose over it, attach your quart of oil, open valve and turn engine backwards (either at crank or if your serp. belt is on you could turn the alternator) until you suck in at least a 1/2 quart. Button everything back up and then crank without the orange ecm + wire connected 'til you see some oil psi. funnel was around $3.....
