Maybe you damaged one of your ign. wires while removing them? You can look under the hood at night while the car is running to see if you have any spark leaks thru the insulation on the boots or coil. That usually shows up pretty good in the dark. Push rods were all seated properly? Rocker shafts securely fastened to the towers?
