Problem with my Cruise control
straycat990
Senior Member
Hey guys/ gals .. the problem I am having is that while driving with the cruise control engaged if I click for high or low beams the cruise control turns off and I have to reset it. Any one else had this problem and if so how do I fix it?
thanks again,
David Morgan
87 Turbo T
Yep, mine does the same thing intermittently. The main time I notice it is when I use the turn signal (to change lanes on the highway) the cruise kicks off. I'm figuring it's a connection in the turn signal stalk/steering column. I haven't dinked around fixing it yet.
sounds like your multi function stalk is on its way out.. You are gonna have to replace that stalk I believe.. These aren't easy to find either..
