never seen one loose the program
what is everything seems to be working fine ???
Has fuel and Spark.
were the plugs pulled and checked ?
Yes, changed the plugs
when keyed on is the fuel pump coming on and does the rail have pressure (around 40psi)
Yes, we have fuel pressure
not prime should only last a few seconds and an external pump doesnt have a check valve to hold pressure when its off
was the ignition module checked ?
Changed the ignition module.
cam sensor should be checked both cap for operation
Changed the cam sensor
do visual check of the cam sensor reluctor disc which can come loose an move from its indexed spot and cause issues
if you have fuel pressure and a working cam sensor ... caspers sells a simple to use tester that speeds up a no start issue but you claim it runs but poor so something is amiss ..
http://www.casperselectronics.com/cart/index.php?route=product/product&product_id=925
Will have to try this and see what I can find
crank sensor can be visually checked that it isnt rubbing (balancer wobble happens) but can be replaced cheap enough
tps can be checked with a voltmeter (or connect to the bS3)
visual check all vac lines
having a car with BS3 you really should get a laptop and connect to the ecu and learn whats what and log data .. theres a well written help manual to learn how to use BS3 .
http://bigstuff3.com/manuals/
some of basic trobleshooting checks with voltmeter can be read up on this site ..
http://vortexbuicks-etc.com/[/QUOTE]
Once the plugs where changed it fired up but ran really rough for about 5 seconds and dies. Almost like timing is way off.
