87gnblackdemon
Don't Be Redikulas!!
- May 24, 2001
Me again, I rely on you guys..
Two Questions.
I have my power wire to my battery fused with a 80 amp fuse the wire is 4g. It goes to a dist. block that has two 50a fuses in it and then two 8g wires come out and go to each amp. Aren't the fuses in the dist.block protecting the 8g wires?, or do I need to add inline fuses to them as well?
I am going to power my a amplifier fans that I am going to install by going to one of the amps power wires in the dist.block. I am going to fuse that wire, but won't the 50a fuse that is already in the dist.block be a problem?
Two Questions.
