PS axle has lateral movement?
nuc
I was just remounting new tires and I noticed that I can push in and pull out the passenger side axle maybe a 1/4". The drivers side has no movement whatsoever. What would allow lateral movement of the passenger side axle in the tube?
Thanks in advance :)
free play between the end of the axle and the center pin in the differential. some play is normal- but anything more than about 1/16" means that something is getting worn out. time to pull the cover and see what's going on.
I will pull the cover and take a look. Will there be shims that I can add to take out the free play?
Thanks for the help so far. :)
'87 GN
nope.. no shims. the end of the axle shaft rides against the pin.. the c clips go in, the axles are slid out until the clip bottoms out in the spider gear, and the pin is inserted to keep everything together and tight.
