Pt60
rssooner
I am thinking of getting a PT60. Any input on this turbo would be greatly appreciated.
I currently have:
50lb injectors
3200 Stall
Stock Heads
Stock Cam
SMC alky
307 walboro (hotwired)
3" exhaust/THDP
What is a ballpark ET with this setup?
Thanks very much for the input.
I was told that anything bigger than a PT/TE60 would require heads or at least porting the heads. Anything bigger would be a gamble on air flow with stock heads. Any thoughts on that theory?
Bogus! For the money spent you cant beat the pt-61 with the new wheel. Heads definately help you reach the full potential, but aren't needed to go up 1 mm on the compressor wheel......
check out PTE for the PT-61.
You can also look into John Craig
And for a little more Jack Cotton!
