Pt6169e What Mods?
BOOSTD1
Currently Run A 12.9 At 106
Hotwire Kit
340 Walbro
Fpr
3"thdp
Scan Master
160 Stat
And The Rest Stock
I Have
50lb Msd Injectors
23 Row Stock Location Intercooler
Rjc Plate
62 Mm Trottle Body And Dog House
Umi Control Arms
H&r Sway Bar
Pinnion Snubber
3400 Vil Stall
What Am I Missing Becides Akly And Tt Chip And May Be 65lbs Injectors ,champion Heads, And 212 Roller Cam
Would Like To Run 10.5 To 11.0
what is your timing , boost set when racing. Do you use sticky tires. we need more info. I was running low 12's w\ stock turbo ans 36# inj. you have enough for 11's w/ good tires and 25 # boost.
I would start with the alky, but with alky I think you will be okay with the 50's. On the cam that is up to you. I am sure you will gain HP with it, but there are plenty that have run deep in the 10's maybe faster on the stock cam. I really think you have enough now to give it a go. Then tear it down over the winter and swap in the cam when you do the heads. You might be surprised. Good luck and I hope this helps
Combos
How much boost you leaving at? are you on the e-brake?, line lock?, are you breaking loose and spinning traction problemos? you have that bad ass H&R antisway bar..You have a lot of nice boltons very very nice man I would think you would be mid 11's at least . An old friend bracket raced his GN with a stock turbo no more the 20psi @WOT,ford supercoupe injectors alil bigger then stock 28lbers, line lock front and back, launching at 8psi, MT drag slicks /tubes screwed to the rims, one air bag right rear, stock control arms top and bottom, no hop bars, stock sway bar in the rear no sway bar in the front,fiberglass front fender and hood, Conley mag4 chip 32* timing at WOT, nothin but C16, and ran consistant low 12's.,12.1,12.2 all day at 5280ft. He took her to Roswell N.M Dragway @ 3500ft and he busted into the high 11's a 11.89, 11.92 with a new tranny brake he was gettin used to 2nd or 3rd time used since installing. I think if you get her dialed in, with right sticky tires, engine combo tuned correctly you will be there.. That mutha ought to spool uplike a Screaming Banshee on fire coming out of hell with that screaming-turbo and and kickass PTC 3400 torque convertor combo.:eek: :eek: You need get her dialed in and kick some booty...:eek: :eek: Anyway GOODLUCK sorting it all out!!!!!
Foot Braking With Around 5lbs Of Boost Any More It Will Push Through The Lights
