PTE-44 FS or TRADE
buttonfly
The stable....
I have a PTE-44 I was going to use. It has a .63 exhaust housing, it has been ported to an atr pipe with external wg. I bought it to use on my car, and I'm running a THDP. The waste gate hole doesn't match up with my pipe. So I thought before I went looking for a new unmolested exhaust housing I might see if anyone would be interested in it. I bought it from a local guy who only had dyno time on it and it didn't net him the power he wanted. The turbo has no play in it what so ever. I personally have never run it on my car. Pics are availible for interested buyers. Ill try to put some on here tonight 10.2.06. So you guys can just look at it. I may be interested in a trade for another turbo, or if anyone has an exhaust housing for it. I gave $550 for it and would like that out of it. Thanx Jason
turbo
Hey jason. I currently have a 49 w stock exh housing. what is needed in terms of upgrades for this turbo? how much is needed for shipping to 10016? my downpipe is stock and the actu is adj in the stock location. if i wanted to use you exh housing what would i need? thanks Jeff
Well your going to run into the same problem as I am unless you have a downpipe set up for an external gate. I didn't think anythink of it when I bought it, but it doesn't match up perfectly with the puck on my houston dp. So Ive thought about just changing the housing, and I cant find a used one, and really dont want to machine this one or spend 200 on a new housing. If your are still interested I'll get shipping for you. thanx Jason
To run this turbo you would need a downpipe set up for an external gate. Turbov6 has an atr on here for sale right now. It would work perfect.
turbo
can i take that turbo and bolt it up to my stock exh housing to work w stock down pipe? what converter do i need to run this turbo?
Im not sure if the the stock exhaust compressor housing will work. This turbo works fine with a stock to 3000 stall. I think stock works just fine. Just to clarify you are talking about the exhaust wheel compressor housing, and not the stock elbow?
