Puck Puck Puck
tclark1722
I just installed a te44 and a 3" dp there is almost no boost I think it's the puck. How do I make sure the puck is align correct. Thanks:confused:
Does the puck arm swing free(back and forth) You can put some grease or vaseline on the puck bolt up the downpipe and close the arm on the wastegate, the grease will leave marks showing you if it's sealing completely or not.
hay thats what I needed a way to check the puck...sometimes a rookie makes it harder than it has to be. thanks turbojd
