Right now it's a shortblock with the oil pan and front cover on. No accessories ,heads, manifolds, etc. I tore it down as far as it goes. It's a spred leg design cherry picker, it should fit nicely going in from the side. Thanx for the info!
Getting the time to take the starter wires off and the bolts you've mentioned is taking longer than to break it down to it's current state.
After a few sets of hg's one should be good at disassembling the topsode of the motor :frown:
I think I'm gonna try those ICS gaskets this time, the stockers haven't given me any luck so far. I'm starting to believe that the garage I used to swap the fuel pump didn't do it or kept the one I gave them to put in. A hotwired 340 shouldn't be going lean with a 61 turbo on 15psi with 50's. Time to use the aeromotive pump that's been sitting here......
