I took the GN out and wanted to make a pass or two just to check out the new transmission.... Well First run at 20 psi had about 4 degrees retard and
O2 about 770 so I increased fuel 5% on the chip and made another pass.
I about died when I looked at the turbo link screen ! 22 degrees peak retard at the end of the run .... I was looking at the road and the boost gauge and missed it.... man I hope I did not hurt it... It ran ok on the way home and seemed ok but I figured out the Alcohol system failed.
I get home and pull the pump out and one of the wires looks like it may have broke off the lug on the pump. The pump look rough and although it ran out of the tank I would like to replace it.. Well Id really like a new Razor system but 600 bucks is 600 bucks.... I don't need to spend....
The pump is a Carter the numbers stamped on it are 4EI4C as best I can tell...
I'll take it to the autoparts store and see if they can match it up but thought I ask here too.... Crap that was a bad feeling..... I need to get something up higher ot something to alert me of this sort of crap... other then running slower then I expected there was no warning popping ping nothing....
Yeah its an old SMC intank pump..... dinosaur....
