Pump test pressure questions....
WH1
5150
I just installed a used 2003 SMC single M15 nozzle kit. When I hold the test button down, motor not running, the gauge only reads 34. Is this normal or what should it be and how can I verify my pump's up to snuff? Thanks.
Well see thats a loaded question. As pump pressure has to do with the pump speed setting on your controller.
Now assumming the pump speed is fully cranked.. pressure should be at least 70 PSI my understanding on the SMC kit. Some models had larger pumps that would go over 90-100 PSI. Contact Steve for exact specs as to pressure you should be looking for.
34 PSI "if" the guage is accurate.. fugedaboutit..
