turbov6joe
Signal 1 J-12
- May 22, 2002
Some of you might recall me posting about my TTA using coolant, well the short of it was a leaking headgasket at one of the water jackets; not blown, just leaking. Coolant was being sucked into mainly cylinders #1 and #3 causing those jugs to go dead when running. I replaced the HG's and changed the oil which had very little signs of coolant in it and buttoned the motor back up. Well, right after throwing the torque wrench on the rocker bolts, I noticed that #1 intake rocker was loose enough to wiggle around fairly significantly. The rest of the rockers were nice and tight as one might expect them to be with the factory backlash. Anyhow, I dismissed this as maybe the lifter was pumped down from sitting and the motor was made ready for start up. Once running and all the lifters pumped back up, I had a BAD lifter/rocker rattle comming from #1....prolly that intake rocker that was loose. Now here is what I think, I need your opinions as well.
Like a fool I did not check push rods to see if they were all straight, and I failed to yank out the lifters to inspect them either....my bad for sure!! I did however look at the cam lobes the best I could and did not see any tell tale signs of wear or discoloration. The motor runs way too smooth for it to be a bad valve, so I'm kinda leaning away from that. The best I can come up with thus far is that is could be any of the following things:
lifter stuck in bore
bent pushrod
piece of debris under the rocker or rocker girdle not letting it seat all the way down.
wiped cam lobe
lifter took a crap
lifter is failing to pump up
lifter is worn for whatever reason(s)
Mr. Murphey is in my motor
One would think that if the cam lobe is shot, the motor would not run as well as it does. One might also conclude that because of all that non-compressable fluid in the cylinders, something bent. Figures it's on the DS where taking off the valve cover requires much more work. I plan on checking things when I get up Monday afternoon. I'm starting with the KISS things and working my way down. I'm praying that the pushrod is bent thus taking out preload, but that would be too easy. Any other ideas out there???
bent pushrod
wiped cam lobe
lifter took a crap
