Actually I gave the batton to Frank for him to run with.
See My reasearch into this.. boy have I spent time, is the following.
The chiseled piece was using a 1.7 ratio roller rocker. Problem is those fulcrums are are set much deeper than the TTA fulcrums. By the time you take into account the shank on the stud, the guideplate, and the height of the pedestal, you have a lot of room taken up. So on the 1.7 rollers, what was done is mill the pedestals, drill and tap for a 7/16 stud, use isky adj guide plates, and then use 6 BBC 7/16 studs, and 6 BBC stud girdle studs. Mind you one question was if the stock VC's would clear the aftermarket arms, hence why that car has the custom fab'd ones. All aftermarket roller rockers have the fulcrums in the same depth. Our TTA rockers are more squished. Hence the problem.
Now my thought was using the roller fulcrum rockers from a 3.8 series II motor. Those are a 1.6 factory ratio, but the fulcrums are full needle bearings. And the rocker is identical geometrically as the TTA one. The only problem I ran into was the hole in the fulcrum was 5/16, and our bolts are 3/8th. So the rockers would need to be drilled out to make work using 3/8 studs. this is where I passed the batton to frank since he killed a set of factory rocker arms. I havent heard news as to what happened.. i'll follow up. My motor is going on a stand the next few weeks to get ideas sorted.. So this is one area i'd like to address.
BTW, there is a company called Intense Racing that makes the series II rockers up to a 1.9 ratio.
Joe, the cometics require super smooth surfaces for them to seal. On a street car, careful what you ask for.I'll be doing the 9441's as well with the ARP's.
Now for thinking caps, how bout adding 4 degrees to the cam
hehehe
