Putting motor back together and got to the heads.Do all the bolts run threw a water passage and if so what sealant to use on the threads?Can I just use liquid Teflon?Also noticed there is no dowel pins in block should there be to hold head and gasket in place?Using ARP head bolts instructions say 75 LB is that correct?
Shaun
Shaun
