I put my cam in today and rebuilt with new bearings . I want to put the timimg chain on and line the dots up , but i was not sure what way the cam want its a comp cam 206 it has two nipples on the top and a flat spot on the bottom. So if number 1 cyl is TDC the valves should be closed and the cam should be with the niples on top right . I want to make sure before i put it in this weekend , dont want to pull it apart again.
I would like to make it to the track this year to get a run in with the cool air. How many miles should i put on new crank and rod bearings before running it hard at the track.
thanks guys
thanks guys
